The DVE uses percentages so that it is agnostic to the Pixel count being used.... This has been how Ross Switchers have worked since DVEs were brought into the switcher with the Synergy Series and the Squeeze & Tease 2D DVE (FYI that was before even I worked at Ross....)
On Carbonite you can go up to 5x on the Zoom before you are "going behind the viewers head" and thus no longer visible...
The Reference point is the "center" of the image. 100% X Pos would be exactly one "screen" to the right. If I made a 2 box with 50% size then 25% is going to place it to the right with exactly the room needed to keep it completely visible and if you zoom up you would see the center stay put while the image scales up.
1 Full Screen to the Left is -100%...
There is no MiniME Clean Feed you just have the MiniME PGMs... but since there are 4 MiniMEs you could Put MiniME 1 into MiniME 2 Key 1 DVE Key and then use Key 2 of MiniME 2 for the replay graphic... You would still be able to bring that as a re-entry on the PGM ME.
As for Memories -- you can easily use the Effects dissolve system to do this... Make Memory 0 of the bank the "normal" position and then you have the 1-9 buttons that you could build the positions for your 9 zoom locations. using Effects dissolve it will just zoom up at the rate you set when you stored the memory and then you can use 0 again to zoom back to normal as well. And all of those can even be recalled in a custom control as well.
Sent: 08-10-2021 14:40
Subject: Screen Coordinates & Replay Zooms
I am thinking through how I want to set up a Carbonite switcher I'll be using for a sports broadcast I'm doing in a couple weeks and had a few questions that I couldn't find the answers to online.
I will be on a traditional Carbonite 2 ME and plan to be in the switcher mode with the two full MEs and 4 MiniMEs.
- What are the switcher screen coordinates for a standard 16x9 HD picture when manipulating DVE parameters? For example XY are both at 0.0 in the middle with size 1.0. What are the coordinates at the far left/right and top/bottom?
- What is the best way to accomplish zooms for replay purposes on the Carbonite? I'd like to break the screen up into 9 regions (top left, top middle, top right, middle left, middle middle, and so on…) and also zoom in 2x.
I'm used to using local E-MEMs on GV systems to recall those specific coordinates on the ME dedicated for replay and thought I'd do something similar with the Mems on a MiniME.
Would it work if I had Key1 as a DVE with that MiniMEs clean feed as the source and then Key2 as a replay chip that would always stay above that and not grow when doing zooms on Key1 miniME clean? Are there even a clean feed option for miniMEs?
Hope that makes sense. Let me know if I need to elaborate on anything.
Thank you!
Parker
