  • 1.  Setting up RossTalk for the Dashboard
    Posted 06-22-2018 08:50
    Apologies if this is a simple problem but I am rather stuck. I am looking to set up my Dashboard (version 8.2.0) so it can receive commands from a windows PC to fire custom controls I have set up. Both these machines exist on the same Ethernet network (I can ping the IP address but no command protocol appears).
    I know the Dashboard's IP address and I have turned on GPI listening for Port 7788 but I am unsure what to do next. When I tried to set up the Ethernet communications (http://help.rossvideo.com/carbonite-device/Topics/Devices/RossTalk/RossTalk.html#topic.rosstalk-control) there was only the option to configure an Expression rather than a generic_1.0.
    I know I am doing something stupidly wrong so any assistance would be gratefully recieved
    Adam
  • 2.  RE: Setting up RossTalk for the Dashboard
    Posted 06-22-2018 09:29
    Your probably on an older version of the Switcher as well. Carbonite is up to v13.0.1 and DashBoard is now at v8.4. You should download both :)
  • 3.  RE: Setting up RossTalk for the Dashboard
    Posted 06-22-2018 15:15
    Thanks, if I download and install them, will I have to build my layouts and camera connections again or will they port over without a re-build?
  • 4.  RE: Setting up RossTalk for the Dashboard
    Posted 06-22-2018 20:03
    all switcher files will be able to be loaded. The current set will be the same when it reboots after the upgrade.
