depending on what desk you have but what we do for that is use your ME 1 not the P/P ME.
so use the ME1 to build your 4 DVE keys in the config that you want and use your P/P ME to drive the graphics over lay.
your ME 1 will be able to run this and not the Minis 1 to 4 as they can only use 2 keys
but you could use two mini MEs to build this .
1.with the use of their 2 keys on each for your cameras so for eg. Mini 1 has cam 1 and cam 2, both on the top half of the the screen for Mini 1.
2. mini 2 have cam 3 and cam 4 on the bottom half of the it's screen but have Mini one cut on on Mini 2 so that its behind but of your keys on MIni 2
3. putting one of the mini MEs in program on the other Mini ME, then take that mini to air on your P/P me and the graphics running through that.
I work in a shopping tv channel and we run our graphics on key 4 on our P/P ME as then they are always there when needed no matter the shots/ effects running
hope fully that helps
Andrew
Technical Studio Director
Create and Craft
Andrew Grieves
Technical studio director
create and craft
Sent: 12-28-2021 15:51
Subject: 4 Box
We are trying to create a 4 box with a graphic on top. The problem is that all of our keys are being used for sources.
For example;
Key1- CAM 1
Key2- CAM 2
Key3-CAM 3
Key4-CAM 4
Usually with other 2 boxes or 3 boxes we will integrate the graphic on the last Key so it can go on top of the sources, but however with a 4-box since they're all being used for a source we are unsure of where we need to integrate the graphic. We tried to use a Minime key, but it didn't seem to work. If anyone could please help we would appreciate it very much.
Krissiha Lagos
Technical Director/APC Operator
KULX
