  • 1.  Lock out panel
    Posted 05-10-2020 22:45
    Is it possible to lock a carbonite panel? Just to prevent anyone from walking up and making any changes or accidentally putting some on air. Ideally just with a few keystrokes on the panel or from a custom control?
  • 2.  RE: Lock out panel
    Posted 05-10-2020 23:13
    You can use the Control Panel test to prevent buttons from doing anything unless you intentionally exit that menu and start pressing buttons:
    To Run the Control Panel Test
    Test the functionality of any of the buttons, knobs or fader and positioner on the control panel.
    1. Press MENU > System > NEXT > NEXT > Diag Tests > Contrl Test.
      The second line of the display shows the current button, knob, positioner, or fader being used.
    2. Test the button, knob, positioner, and fader you want to check.
    3. Press the MENU and Exit buttons at the same time to end the test.
