I'm running into an odd experience with a video file I've applied as a material within a scene in XPression Designer 9. The animation, which is 180 frames, contains an alpha channel and was converted from a Tiff sequence to an XPression compatible file. The issue arises when I add the scene to the Sequence and play it out through my Virtual Output. The file plays to the last frame of the animation, and it appears to show a remnant of the alpha channel from an earlier frame. I've double-checked the alpha channel from the file I rendered out and checked the project file, and neither of those shows anything other than the logo at the last frame of the animation. I've also rendered out a Targa sequence with a premultiplied alpha channel, to ensure it wasn't an alpha channel issue. Looking at the image below, the portion of the image which shouldn't be there are the circular rings behind the logo text/target brandmark. Is there an alpha setting I'm missing in the material settings or is this an issue with the output to my Virtual Output?
For context, the full animation is here:
Side by Side - Fill and Key
Here is a screenshot of my Virtual Output window:
