  • 1.  XPression playing clips at twice the speed
    Posted 04-18-2017 19:49
    Hi all,
    I'm currently doing a gameshow using XPression where I'm playing videoclips from inside Xpression but just as a quad and not using the server channels.
    I'm having an issue that after a while suddenly the clips start playing at double the speed or faster than it normally should.
    I've checkend and there is no way I think that I can set the playout-speed like you can for example with a scenedirector.
    I am using two scenes that have the same videomaterial in it which are being shown on two different outputs so I'm not sure if that would have to do something with that.
    When you are using a renderview from a scene on a different output, you have to set the playspeed at 0.5 but that is "normal" behaviour. However for material where you play the material using xpMaterial.Play() I never had this before. Does anybody know what is causing this?
    The only solution I have now is to close the XPression-application and to restart it.
    Thank you,
    Kenneth
  • 2.  RE: XPression playing clips at twice the speed
    Posted 04-18-2017 20:11
    Is the video clip at the correct frame rate?
  • 3.  RE: XPression playing clips at twice the speed
    Posted 04-19-2017 22:09
    I didn't check the actual file, I will do so tomorrow but I would imagine it to be the correct framerate yes. We only work with one standard.
