  • 1.  strange behaviour / bug?
    Posted 12-14-2017 07:28
    Hello all,
    I'm having a little issue in a projectr where I'm using Transition Logic.
    On one of my templates I have added an outro animation that should be played when we're moving on to another scene.
    However when this scene is on air and we load another scene, the outro plays fine, and the next scene is ready to but the next scene gets taken off air.
    Is this a bug or something?
    I'm running build 3938.
    I've uploaded the project on your brickFtp.
    Best regards,
    Kenneth
  • 2.  RE: strange behaviour / bug?
    Posted 12-14-2017 16:51
    Which folder on the FTP did you upload the project to, and what is it called?
  • 3.  RE: strange behaviour / bug?
    Posted 12-14-2017 17:57
    Hello Brian,
    I just uploaded from the webpage. It didn't allow me to specify a folder. It's called Transition Logic if I remember correctly. It's an XPP.
  • 4.  RE: strange behaviour / bug?
    Posted 12-14-2017 19:06
    Delete the Take Offline event and the Jump to Frame 0 Event from the end of the Out SD.. You dont need those because the scene automatically gets taken offline when the Out SD has finished playing.
  • 5.  RE: strange behaviour / bug?
    Posted 12-14-2017 20:18
    OMG... I didn't know that was still in there... I can't believe I haven't seen that.
    Thanks Brian.
