  • 1.  Progressive project animations
    Posted 07-08-2018 06:11
    Hello all,
    I'm building a project in 1080p 59.94.
    When I'm creating animations, I'm under the impression that the playback speed is not correct. It seems faster.
    Could it be that I need to double the length of my animation controllers? So instead of having an 8 frame dissolve, I need to make it a 16 frame dissolve?
    Or is it just my Developer which is playing the animation incorrectly and will it play on the XPression Studio properly?
    Thanks,
    Kenneth
  • 2.  RE: Progressive project animations
    Posted 07-08-2018 13:57
    An 8 frame dissolve in 1080p will be twice as fast as an 8 frame dissolve in 1080i. It will be approx 1/8th of a second (8 x 1 / 59.94), instead of 1/4th of second (8 x 1 / 29.97).
    Is that what you are asking?
  • 3.  RE: Progressive project animations
    Posted 07-08-2018 20:34
    Thank you @bford for your reply. So I do have to make my animations twice as long then.
