  • 1.  150–200 ms delay for response from Ultricore BCS via SW-P-08
    Posted 9 days ago
    Hi everyone,
    We're using the SW-P-08 protocol to control an Ultrix router managed by an Ultricore BCS.
    When our clients send a CONNECT command to the Ultricore BCS, it consistently takes around 150–200 ms to receive the CONNECTED response from the BCS controller.
    I'd like to ask whether this response time is considered normal for SW-P-08, or if it might indicate a configuration or performance issue.
    Kelvin So
    Maxson Nework limited
  • 2.  RE: 150–200 ms delay for response from Ultricore BCS via SW-P-08
    Posted 9 days ago
    @Mike Pomerleau @Kevin Anderson
    This is really meant for the Router Forum - however maybe you can answer it here?
