A new build of 10.7_5586 is available and ready for download at
https://transfer.rossvideo.com/f/d49b1d35ef820c83Changes in this build:
- [implemented] NDI libraries have been upgraded to version 5.0
- [implemented] object manager column widths are now stored in docking layouts
- [improved] remote sequencer now supports UI colors for more than six channels
- [fixed] layer objects as a child of a group could cause the bounding box values to be incorrect
- [fixed] HTML5 Plugin - Assign Columns now populates fields if there is leftover DL config
- [fixed] NDI output luminance levels could be incorrect when using color space conversion
- [fixed] HTML5 Plugin support @MACRO@ substitution for OpenMAM filter strings
