A new beta build 10.7_5587 of XPression is available
  • 1.  A new beta build 10.7_5587 of XPression is available
    Posted 09-14-2021 22:23
    A new build of 10.7_5587 is available and ready for download at https://transfer.rossvideo.com/f/5d1b46db34f0fef9
    Changes in this build:
    • [improved] material manager will not hide when deleting fonts or folders
    • [fixed] HTML5 Plugin - Multi-Column Datalinq now assigns column information correctly to other fields
    • [fixed] newline delimiters in the text datalinq did not work when there were also comma delimiters in the same row
    • [fixed] deleting a folder after it has been moved could cause an AV
