A new build of 10.7_5588 is available and ready for download at
https://transfer.rossvideo.com/f/2a299e9d3c2eaec1Changes in this build:
- [implemented] a preference to disable the automatic CII X\ requests when cueing an item
- [implemented] 12G support for AJA capable cards (requires AJA driver 16.0+)
- [improved] changed template data after a scene has already been cued will now be applied when going on-air
- [fixed] HTML5 Plugin would AV if emoji text was added
- [fixed] HTML5 Plugin will maintain UIC field override of XMP data when the scene is edited from the NRCS or from a saved graphic
