A new build of 10.7_5590 is available and ready for download at
https://transfer.rossvideo.com/f/496b0b7faf0fdeb6Changes in this build:
- [note] API has changed
- [implemented] can now move xpTakeItemGroup in xpSequencer via MoveGroupByIndex or MoveGroup
- [implemented] HTML5 Plugin support for the "reset" functionality introduced in build 5589
- [fixed] adding a server channel could AV if no outputs were added
- [fixed] TCP XML/JSON Datalinq unable to link to multiple tables.
- [fixed] XPression could fail to browse for folders in 64 bit versions
