A new beta build 10.7_5598 of XPression is available
  • 1.  A new beta build 10.7_5598 of XPression is available
    Posted 11-02-2021 14:38
    A new build of 10.7_5598 is available and ready for download at https://transfer.rossvideo.com/f/29d646288200a21e
    Changes in this build:
    • [implemented] JSON Datalinq - Table Presets Introduced
    • [implemented] xpNLELoader now has a framerate property (default 29.97)
    • [implemented] a checkbox in the SwissTiming datalinq to ignore the checksum
    • [improved/changed] the supported 10.2 Matrox DSX Topology driver is now 10.2.101.26081 (SP1)
    • [fixed] HTML5 Plugin - Multi-Column Datalinq now assigns column information correctly to material fields
    • [fixed] shows and sync groups in Project Server Manager now populate their details in the lower panel when using the arrow keys
    • [fixed] HTML5 Plugin populates hidden fields in MOS objects. Further preview changes downstream are not required
    • [fixed] xpNLELoader could calculate the wrong duration for rendering
    • [fixed] installers for XPression apps now have consistent images
    • [fixed] taking a take item offline with a live source material using an on-board scaler could hang if the next item to preview also involved that input
    • [fixed] taking online an item with a live source material using an on-board scaler could cause a green flash on the Matrox XMIO5 12G
    • [fixed] an input spanned across multiple horizontal Tessera outputs using the on-board scaler could show a vertical black line on the Matrox XMIO3
