A new beta build 10.7_5599 of XPression is available
  • 1.  A new beta build 10.7_5599 of XPression is available
    Posted 11-10-2021 14:58
    A new build of 10.7_5599 is available and ready for download at https://transfer.rossvideo.com/f/173fc1aba3378731
    Changes in this build:
    • [implemented] Support for Graphite driver version 6.0 (previous versions no longer supported)
    • [improved] further rendering performance improvements
    • [improved] animation controllers can now be scaled inside a scenedirector
    • [fixed] HTML5 Plugin Streamline filter facilitates multiple directories
    • [fixed] TCP XML/JSON Datalinq missing text encoding options for JSON
    • [fixed] materials could fail to load metadata if the texture cache is full
    • [fixed] using "Take Offline Entire Framebuffer" keyboard shortcut would not take all layers offline
