A new build of 10.7_5602 is available and ready for download at
https://transfer.rossvideo.com/f/2a16072236ab2788Changes in this build:
- [note] API has changed
- [implemented] the XPression Video Codec 2 is now included in the 10.7 builds
- [implemented] XML Datalinq - Table Presets Introduced
- [implemented] xpBaseObject.FaceCount to retrieve the number of faces on an object
- [improved] Clip Store Manager now shows the IP address for files received under the Transfer Status tab
- [fixed] HTML5 Plugin could change the channel or Tessera source of the target scene during convert or replace template when editing an object from the NRCS
- [fixed] materials used with staggered animations would only be applied per character
- [fixed] HTML5 Plugin did not handle the Scale and Texture Scale fields correctly
