A new build of 10.7_5610 is available and ready for download at
https://transfer.rossvideo.com/f/f2e4634a85e526aeChanges in this build:
- [implemented] Visual Logic "Convert Epoch Time" Date Time Block
- [improved] The Dashboard DataLinq now support the Visual Logic Datalinq block requesting multiple data points.
- [fixed] when a 3D lines object with no points had its percentage changed an exception was raised
- [fixed] MOS element action INSERT only inserted first of multiple stories
- [fixed] deleting the only category in a project would reverse the order of scenes in the scene manager
- [fixed] connecting a event block to a input selector block would cause an access violation
- [fixed] connecting a event block to a sort selector block would cause an access violation
