A new build of 10.7_5618 is available and ready for download at
https://transfer.rossvideo.com/f/6eda9373a4d42fe5Changes in this build:
- [implemented] TCP XML/JSON Datalinq - Command Parsing
- [implemented] a keyboard/gpi shortcut for starting or stopping a recording
- [improved] increased XPression Clip Store receive buffer
- [improved] XPression Project Server installer now detects if a newer database engine is installed
- [improved] Media Control Gateway clip list generation
- [improved] clip browser clip list generation
- [fixed] Open Record Client button in Record Monitor would not open any record client if none were selected
- [fixed] selector blocks would fail to output when a block with an input was connected to their inputs
- [fixed] an access violation would occur after refreshing search results of a deleted material or font
- [fixed] Media Control Gateway could run out of memory with large cliplists
- [fixed] HTML5 Plugin multicolumn static list interpretation, introduced in build 5611
