  • 1.  A new beta build 10.7_5624 of XPression is available
    Posted 03-30-2022 20:33
    A new build of 10.7_5624 is available and ready for download at : Redacted
    Changes in this build:
    • [changed] logging destination to ProgramData
    • [implemented] NLE plugins can now configure and switch between gateways
    • [fixed] increased the default number of simultaneously loaded projects to 10
    • [fixed] HTML Plugin did not interpret the window close for the pop-out preview, OpenMAM nor Browse Metadata after a Chrome update
    • [fixed] Clipstore REST API clip endpoint would not contain "hasproxy"
    • [fixed] HTML5 Plugin clip stills will now display correctly
    • [fixed] Remote Sequencer could run out of GDI objects when playing the up next preview
  • 2.  RE: A new beta build 10.7_5624 of XPression is available
    Posted 04-04-2022 12:15
    DO NOT INSTALL THIS BUILD
    A bug has been discovered with this build - after installing this build all framebuffer and project server settings will be lost.
