A new build of 10.7_5625 is available and ready for download at
https://transfer.rossvideo.com/f/7238909217361c42Changes in this build:
- [implemented] Status Client now reports client disk usage
- [implemented] Project Server Manager now has a transfer status tab
- [implemented] a new CII command X\SWAP to swap the cued take items to air (see CII documentation for details)
- [fixed] XPression could AV while shutting down when using Graphite framebuffer
- [fixed] XPression Studio installer would not properly move its config files to program data on installation (introduced in build 5624)
- [fixed] attempting to delete a row in a static list that conatins no rows would cause an AV
- [fixed] the graphics layer is now always the source of the embedded audio output when using on-board scalers on the Matrox cards
- [fixed] RossTalk SWAP command could cause an AV
