A new beta build 10.7_5632 of XPression is available
  • 1.  A new beta build 10.7_5632 of XPression is available
    Posted 05-09-2022 13:08
    A new build of 10.7_5632 is available and ready for download at https://transfer.rossvideo.com/f/2e643128da203d3e
    Changes in this build:
    • [implemented] an option in clipstore to continue clip sync if a clip fails to sync
    • [improved] HTML5 Plugin recall id workflow. Reflect fulfilled clip. Remove recall id from existing clip
    • [fixed] removing a license could cause an AV in license tool (Introduced in 10.7.5629)
    • [fixed] the material manager would allow you to delete the only active layer for a font if there was more than one layer
    • [fixed] XPression would fail to output syslog
    • [fixed] forwarding CII gateway commands to itself would cause the UI to freeze
    • [fixed] improve clipstore sync speed for large databases
