A new build of 10.7_5636 is available and ready for download at
https://transfer.rossvideo.com/f/4de839e635f01eb2Changes in this build:
- [improved] HTML5 Plugin honours new Gateway setting to maintain edit mode when a drag is detected
- [improved] HTML5 Plugin honours new Gateway setting to block use without an NRCS
- [improved] Remote Sequencer now greys out "Take Offline" if the item is offline
- [fixed] Adobe Premiere NLE plugin could timeout waiting for frames that were already received
- [fixed] it was possible to close the menu bar in bluebox causing an AV
- [fixed] it was possible to close the upgrade window in status client causing an AV
- [fixed] NLE plugins no longer attempt to perform a remote update
