A new build of 11.1_5750 is available and ready for download at
https://transfer.rossvideo.com/f/ee8a25538c3ab5e9Changes in this build:
- [note] the version number has been changed to 11.1 beta
- [implemented] new splash screen
- [fixed] ActiveX Plugin shows Maps icon in material field if configured in the gateway
- [fixed] ActiveX Plugin launches Maps to the internal browser if HTML configured
- [fixed] ActiveX Plugin supplies the username to Maps when launching
- [fixed] As Run Log Formatter couldn't parse new arlog files
- [fixed] HTML5 Plugin honours the Clip Store Manager setting that disables the creation of a placeholder
- [fixed] HTML5 Plugin creates the correct MOS abstract for a clip or placeholder after an edit
- [fixed] some existing materials (SDR) could show as all black when used in a project changed to use an HDR colorspace
- [fixed] ActiveX Plugin sometimes wouldn't focus on a selected clip MOS object
- [fixed] Tessera Master could fail to render graphics in rare situations
- [fixed] taking a scene online that uses scaled inputs (Matrox on-board scaler) on a Tessera source where at least one scaled input was offscreen of at least one destination could fail and cause the previous item to remain online
- [fixed] a scaled input (Matrox on-board scaler) offsetted more than the output size to the left (or top) would not show even when upscaled more than would have been required to span this offset
- [fixed] using client index in the Record Client would not start recording unless the client's record button had been pressed previously
- [fixed] Tessera Master could wrongly reflect countdown clock time in certian workflows
