A new beta build 11.1_5761 of XPression is available
  • 1.  A new beta build 11.1_5761 of XPression is available
    Posted 11-08-2022 23:03
    A new build of 11.1_5761 is available and ready for download at https://transfer.rossvideo.com/f/2820a1bc0638ea4d
    Changes in this build:
    • [implemented] Text Format support in RSS/HTTP Datalinq
    • [improved] added warning for effects in Tessera Master
    • [improved] XPression Streamdeck plugin now uses TCP Keep alive
    • [improved] added warnings and disabled unsupported transitions in Tessera Master
    • [fixed] clicking on the layer column in Remote Sequencer when the value is the channel default or the template default and then clicking away from it would set the layer to 0
    • [fixed] video clips played on multiple Tessera destinations that were not previously online could be out of sync (introduced in build 5755)
    • [fixed] HTML5 Plugin would crash on every graphic edit unless the automation was set to MosArt in the Gateway (introduced in build 5760)
    • [fixed] projects would fail to unload via MOS (Introduced in 11.1.5758)
