A new beta build 11.1_5764 of XPression is available
  • 1.  A new beta build 11.1_5764 of XPression is available
    Posted 11-29-2022 01:05
    A new build of 11.1_5764 is available and ready for download at https://transfer.rossvideo.com/f/521da72e0730b666
    Changes in this build:
    • [fixed] XPression could fail to export takeitems to image or video
    • [fixed] scene thumbnails would fail to be generated in some aspect ratios
    • [fixed] project importer would fail to load projects if scenes did not have thumbnails
    • [fixed] HTML5 Plugin will have all buttons while editing a scene within the Octopus NRCS
    • [fixed] HTML5 Plugin had issue when populating other fields from a Radio Button or List Box selection. Introduced in build 10.7.5637
    • [fixed] HTML5 Plugin had issue with multicolumn assignment to fields whose published order required sorting. Introduced in build 11.1.5762
