A new build of 11.1_5765 is available and ready for download at
https://transfer.rossvideo.com/f/1800055be195fb91Changes in this build:
- [improved] XPression clip asset logging
- [improved] Project Server now uses SHA512 hashing
- [improved/changed] the supported Matrox 10.2 DSX Topology driver is now version 10.2.103.26148 (SP3)
- [improved] Added option to transition audio for take items
- [fixed] Stats Perform Datalinq Source would send improper GET requests
- [fixed] HTML5 Plugin could populate a user control field with incorrect Static data if there had been Datalinq configured previously
- [fixed] Bodet Scorepad DataLinq will now restore the port number from last config
- [fixed] Bodat Scorepad DataLinq hockey penalty indicators not working correctly
- [fixed] RSS / HTTP DataLinq can now send GET requests instead of POST requests
- [fixed] basic authentication in RSS / HTTP DataLinq for URLs that need preemptive authentication
