A new build of 11.1_5766 is available and ready for download at
https://transfer.rossvideo.com/f/d73fe25c98177b39Changes in this build:
- [implemented] Added option in Incoder's processor configuration to fail if the source clip's frame rate doesn't match the specified rate.
- [improved] take items that have unresolved or changed assets will now be sent to Tessera nodes
- [improved] Remote Sequencer now has a Gateway status indicator
- [fixed] carriage returns are handled better in Right to Left text fields. Introduced in 10.7.5609
- [fixed] creating a object using an event marker script can cause an AV
