A new build of 11.1_5767 is available and ready for download at
https://transfer.rossvideo.com/f/fd11cd1270f5e384Changes in this build:
- [fixed] choosing Yes to proceed in the dialog warning than an XPression instance is already running would still cause the application to exit (introduced in build 5648)
- [fixed] installing Project Server on a machine without a preexisting database could cause PS to fail to launch
- [fixed] ActiveX plugin reflects the new clip associated to a recall ID change
- [fixed] ActiveX plugin warns the user when a new clip is selected while editing a clip
- [fixed] Font Tags that would begin with the letter 'u' would underline instead of using a given font's name
