A new build of 11.1_5786 is available and ready for download at
https://transfer.rossvideo.com/f/8f31f8ac2c1ca75eChanges in this build:
- [implemented] HTML5 Plugin subclips support
- [implemented] support for AJA driver 16.2.3
- [improved] HTML5 Plugin performance enhancements
- [implemented] Bodet Scorepad DataLinq - Volleyball
- [improved] Project Server installer now deselects database engine by default if it's already installed
- [improved] DataLinq Server - Notification of change message should also contain table name implemented for ADODB DataLinq, JSON DataLinq, XML DataLinq and XML/JSON DataLinq Sources.
- [improved] DataLinq Server - Copy to Clipboard option in the Log Window
- [improved] set keyframe and delete keyframe dialogs now have pivot buttons
- [fixed] some AJA cards would not enable 12G outputs
- [fixed] Tessera SE could playout at wrong speeds if the first output is excluded
