A new build of 11.1_5791 is available and ready for download at
https://transfer.rossvideo.com/f/bf1e0e3d7a69096bChanges in this build:
- [improved] multiple authentication credentials can now be stored for publishing/deploying projects from Studio
- [improved] the memory usage of the INcoder when slicing a clip into multiple regions
- [fixed] moving multiple objects above another object in the Object Manager could reverse their order
- [fixed] Tessera nodes using virtual outputs in addition to hardware framebuffer outputs could lose sync over time
- [fixed] the unsupported internal keyer option would still be selectable on framebuffer IP cards
- [fixed] on Matrox DSX D25 and Q25 cards, some combination of audio flows and channels that could generate bad audio would still be selectable
- [fixed] removed font tags from appearing at the beginning of published text fields automatically
