A new build of 11.1_5792 is available and ready for download at
https://transfer.rossvideo.com/f/ad41dc923b5d0dd4Changes in this build:
- [improved] XPression ActiveX Plugin Updater will warn if the plugin is still in use before updating
- [fixed] following the first lock to PTP after a reboot, a Matrox DSX 2110 output could playback content at an accelerated speed
- [fixed] Deleting a Visual Logic "String Match" or "String Selector" Block could cause an AV
- [fixed] Clipstore <unassigned> project would get improperly assigned when edits were made to a clip with a blank project field
- [fixed] xpBaseObject.GetOnlineWorldPosXYZ would return incorrect z coordinate when object was in scene root
- [fixed] RSS/HTTP DataLinq Sources freeze while an invalid Dynamic URL RSS/HTTP Source times out.
- [fixed] XPression could exceed it's GDI quota while browsing a large amount of clips
- [fixed] as run log thumbnails would not get deleted automatically over time
- [fixed] DataLinq VL block does not pass along data from sources using table presets
</unassigned>
