A new build of 11.1_5800 is available and ready for download at
https://transfer.rossvideo.com/f/e2c870f89cdea6f2Changes in this build:
- [implemented] ActiveX plugin has a button to show fields when hidden by Visual Logic
- [improved] enable TCP keep alive for TCP clients
- [improved] the color space of the texture or video shader fragment of the original material is now preserved when assigning a new image or video to a published material, or when using a dynamic material (including from the ClipStore)
- [fixed] project server could fail to upgrade via status client if a new database engine is installed
- [fixed] status client would fail to retrieve disk status if xpMonitor is password protected
- [fixed] the Remote Sequencer now reflects Lucid and not UX channels
- [fixed] project server manager fails to sort show names by descending order
- [fixed] Remote Sequencer was asking for previews of Lucid objects
