A new beta build 11.7_5851 of XPression is available
  • 1.  A new beta build 11.7_5851 of XPression is available
    Posted 08-21-2023 15:20
    A new build of 11.7_5851 is available and ready for download at https://transfer.rossvideo.com/f/5e54ecc0448ce75a
    Changes in this build:
    • [note] the API has changed
    • [implemented] the SFP Engine network settings for the SFPs used for redundancy can now be configured on Matrox DSXLE5 and XMIO5 IP cards
    • [implemented] clips can now have the key from one clip and the fill from another clip ganged together
    • [fixed] xpBaseObject.GetScreenSpaceBoundingRect could return the wrong RECT dimensions
    • [fixed] xpGroupObject was missing properties
    • [fixed] edge case exception when exporting a sequencer take item list to xml
