A new build of 11.7_5852 is available and ready for download at
https://transfer.rossvideo.com/f/8b4c124601e46a2dChanges in this build:
- [implemented] FairPlay DataLinq Source
- [implemented] the Remote Sequencer will now reflect a dedicated Lucid channel
- [improved] a ganged key clip now uses its fill as the key if it's a 24-bit clip
- [improved] XPression MOS Gateway now logs the remote port of incoming MOS connections
