Virtual Production Solutions
A new beta build 6.4.2523 of Lucid is available
  • 1.  A new beta build 6.4.2523 of Lucid is available
    Posted 03-16-2022 11:31
    A new build of Lucid 6.4.2523 is available and ready for download at https://transfer.rossvideo.com/f/9c29817ee176833a
    Changes in this build:
      - [fixed] Loading invalid project (uxp) or tracking (uxt) files was throwing errors and could leave Lucid in a bad state
      - [implemented] Lucid internally checks periodically if changes are really stored in the project files (changed could be in only memory if there is any error when writing to the file)
      - [changed] Added XPression License Tool in installer
      - [implemented] Installer now checks if there is a dongle with a valid license for the new version before starting the installation.
      - [fixed] Lucid Studio was crashing when quickly calling events changing Renderer scenes (event actions)
      - [implemented] Lucid API now is OpenAPI compliant and generates automatic Swagger documentation
      - [changed] "API Documentation" button now shows the Swagger document in the OS default Internet Browser
      - [implemented] New options "Play From Start", "Play From Start Loop", "Play From End" and "Play From End Loop" for the Animation Events actions
      - [fixed] Clicking on a Renderer Service that was already selected was clearing the list of available projects
      - [fixed] MOS Service was not saving properly the configuration when changing the selected IP
      - [fixed] Changing the Renderer scene from Lucid (both action and Renderers info popup) was not working properly
      - [implemented] Event thumbnail can now also be queried directly from the output of a connected Renderer
      - [fixed] CII commands were not being replied by Lucid Studio
      - [fixed] Changing the page in the Position panel (using the buttons on the bottom) could not properly change the content of the page
      - [fixed] In the Track Operate panel, a Floor Preset transformation was being changed even when "Nothing" was selected in the "Update" option
      - [implemented] New visual indication in the Events pages dropdown to show which ones contain one or more events
      - [implemented] Lucid Studio (Server) can now detect available Lucid Tracks, Voyagers and XPression using Service Location Protocol (SLP)
      - [changed] Improved management of multiple simultaneous new connections
      - [fixed] When all the connected Lucid Tracks didn't fit on the top toolbar, the auto-horizontal scroll to keep showing all of them was not being activated
      - [changed] Web panel tabs now take their label from the Web Page title instead of its address
      - [implemented] New "Send Command to Renderer" Misc event action to send specific commands to the Renderer (in the case of Voyager, commands to be run in the console)
      - [changed] Removed condition to check if IPs are in the same network
      - [implemented] Lucid Track and Studio now can be registered to SLP to be auto-discovered
      - [implemented] In Logic, when dragging to an empty space an input or output node pin, a context menu will be shown with only the options (nodes) than are compatible with that kind of dragged input/output
      - [implemented] WEB API can now be: Disabled, Enabled for both API and Web access (index.html) or Enabled only for API (API commands work, but index.html doesn't)
      - [changed] Renderer Logic node now informs better the user when there is a missing input
      - [implemented] New logic node DELAY: it waits the configured amount of seconds to propagate the input value to the output
      - [fixed] Calculated NCAM rotation could be wrong when there was some roll in it
      - [implemented] [RVSVOY-406] Added Chroma Keyer Green Weight editor in Chroma Panel
      - [changed] Lucid Driver for XPression now uses XPression 10.5.5508
      - [implemented] Ability to set and run equivalent actions as the Logic Renderer nodes from an Event Action of type Renderer, without requiring to create it in Logic. Renderer Lucid nodes of type string, float, vector, rotator, color can now be set from an event action.
      - [implemented] Support for (external) custom lens files
      - [implemented] Support for NCAM protocol using UDP (TCP connection still available)
      - [implemented] Support for the NCAM Lite (UDP) tracking protocol
