A new build of Lucid 6.4.2540 is available and ready for download at
https://transfer.rossvideo.com/f/c9c9c6141db3fedeChanges in this build:
- [changed] Added note about new Python version 3.10.4 requirement in the User Guide document
- [fixed] API Documentation was not being shown when using SSL
- [changed] Updated User Guide and Release Notes documents
- [implemented] Streamline assets from Lucid Router panel are now supported in Driver for XPression
- [fixed] Lucid Setup panel was losing Track selector occasionally when changing layouts
- [changed] Stream Deck plugin: Added waiting/loading icon and improved connection status management
- [fixed] Some issues with Text items using Unicode characters (both data from Lucid to Voyager and vice versa)
- [fixed] Lucid API: removing events was updating into a blank event button in online API page and DashBoard.
- [changed] Python upgraded to 3.10.4 (it was using 3.8.2 before)
- [fixed] Chroma key panel Key color preview became "invisible" when Alpha was set to zero. A small frame has been added.
- [fixed] Adding or removing a discoverable custom lens caused script errors in Lucid Track
- [fixed] Track Setup panel was entering an invalid state while custom lens window was open and the selected Lucid Track disconnected
- [fixed] Lucid Custom Lens window still was attempting to retrieve track data even (when manually clicking the button) from disconnected Lucid Tracks
- [fixed] Lucid was not recovering when trying to apply large file directory in Custom Lens options (for example, trying to add "C:/" as a path)
- [fixed] Track Setup panel can become active again if there is any change state in the custom lenses popup
- [fixed] Category navigation (tabs) can reveal page info without selection (with a long left mouse click or a right click)
