Acuity can serve up a connection for aux buses directly to the Ultritouch using OGP on port 5254.
You can build Custom Panels that send RossTalk Commands to the Acuity -- ie be able to trigger custom controls or xpt switches that are programmed on the Switcher.
You can also build custom panels to trigger Caprica Custom controls which then can also send data to the switchers.
Caprica uses the Ross Automation Protocol to talk to the Ultrix Acuity.
