  • 1.  Adding Material Shader Layers that respect the Alpha of the Texture Shader Layer Below it
    Posted 10 days ago
    I have a base layer graphic that is in grayscale. I have several different Team Colors that I need to apply a Photoshop-style color tint/overlay on top of the grayscale texture shader layer. When I add a color tint shader layer on top of the grayscale, the color fills the entire bounding box of the size of the texture beneath it, but does not respect the alpha of the texture. How can I set up the top color tint layer so that it will only apply where there is image information, instead of filling the entire space of the texture image "bounding box". Here is an example of the base texture layer. I need my color tint to respect the alpha where the corners are rounded (Instead of making a fully-filled square):
    Shane Finley
    Dallas - Fort Worth Area United States
  • 2.  RE: Adding Material Shader Layers that respect the Alpha of the Texture Shader Layer Below it
    Posted 4 days ago
    Instead of adding another Layer to the material, you can set the diffuse color of your base layer to the specific Team Color, then use the color blending on the Texture shader to get the right look. I took a cutout of the image you posted brought it in as a .png image Texture Shader.
    Set the Diffuse Color to the Team Color
    On the Texture shader, set the Output Modifier to "Multiply by 2" (you can do the same to the Previous Stage or Current Stage instead as well)
    Jeff Mayer
  • 3.  RE: Adding Material Shader Layers that respect the Alpha of the Texture Shader Layer Below it
    Posted 4 days ago
    On this Jeff, if you wanted to make it a dynamic material that feeds into the image, how would you go about that? - So let's say you have a folder full of swatches, and so as you assign a new team, then the color updates like a dynamic material would?
    Or, do you have to just know the hex code to everything and script it (or visual logic) to change the value on the diffuse color.
    Garrett Hall
    Overtime Elite
    Atlanta United States
  • 4.  RE: Adding Material Shader Layers that respect the Alpha of the Texture Shader Layer Below it
    Posted 3 days ago
    The Dynamic Material would replace the entire material, not just the diffuse color. Easiest way would just be to use Visual Logic to link the hex code from a text object (Datalinq, User Input Control, etc.) to the Diffuse color of the material.
    Be sure you use a different material in your scene for each team, since the visual logic is effecting the project material color, not just each individual scene object.
    Jeff Mayer
