Hey Sean, there's 2 different things here.
1 is the "off the shelf" workflow using a sequencer gateway and remote sequencer.
This video gives a high-level overview. https://www.youtube.com/watch?v=EXwyG17sISM
The API workflow I was talking about is people building their own interfaces and workflows talking directly to the BlueBoxes (and other supported versions).
Sent: 02-14-2023 17:46
Subject: Adding output cards/framebuffers to Xpression Studio
Appreciate that info, thank you. I'm intrigued by your description of a non-MOS environment gateway/Remote Sequencer. Do you know if there is any documentation on that workflow or the API control that you mentioned? I've often wondered if Remote Sequencer could accept remote API calls, as that could be a solution to one of our automation issues.
Sean Henry
Sent: 02-14-2023 04:55
XPression studio can have more channels but not with that card, you'll need to change to another card. It depends on your version of XPression but cards from Bluefish, AJA and Matrox are supported. If you want 4 channels of key and fill you'll also need an XPression Studio Flex license as standard Studio is 3 channels of key and fill.
Regarding bluebox it's also the same requirements. Bluebox can be used outside of a MOS environment using Remote Sequencer and a non-MOS version of the gateway or API application control.
