  • 1.  AI Coding and Dashboard
    Posted 06-13-2026 13:17
    I've been playing around with AI coding for Dashboard. So far I've tried Chat GPT (free) and Gemini (Pro). I must say that I've been able to tackle things that are above my coding comfort level quite successfully. I've found that Gemini Pro has been really pretty decent, but you have to watch it carefully as it gets confused between javaScript and ogScript.
    I'm curious to see if others are using AI as well and if so, what AI coding agents are working well for you?
    TIA
    JerryB
  • 2.  RE: AI Coding and Dashboard
    Posted 06-23-2026 03:18
    Have tried it a bit, and yes, JavaScript vs ogscript is definetly an issue with some of them.
    But the main issue here is that most browsers and AI agents today are based on ES6, while DashBoard is still stuck in ES5.
    And not to criticize ROSS too much here, it's been 11 years ago since ES6 was released, so it's about time to update DashBoard on that front IMO.
    This will be an issue with DashBoard soon, especially since AI is driving more and more coding. And not everyone is familiar with the difference of ES5 and ES6.
    Aleksander Stalsberg
    Norway
  • 3.  RE: AI Coding and Dashboard
    Posted 06-24-2026 14:24
    Hi Jerry,
    There is an upcoming Dashboard 10.0.0 major release which will now support ES6. Stay tuned on the community forum for the release.
    Thanks,
    Cheers,
    Aury Rukazana
    Senior Software Developer
  • 4.  RE: AI Coding and Dashboard
    Posted 07-10-2026 18:46
    👍 Good news.
    Do you know if there will be an update to the style formatting for dropdowns (parameter respects the style definitions)?
    JerryB
  • 5.  RE: AI Coding and Dashboard
    Posted 07-11-2026 10:48
    This is gonna be a massive update to DashBoard in that case, and make it even more powerfull!
    Do we have an ETA for this?
    Norway
  • 6.  RE: AI Coding and Dashboard
    Posted 20 days ago
    Claude has by far been the best, so far. I'm mostly using AI to write complicated javascript functions to manipulate data imports. Gemini has been fine but Claude had more context right off the bat for what I was trying to do with Dashboard and ogscript. I usually provide code templates (out of the Dashboard templates that have been floating around the forum or previously programmed panels) that are similar to what I'm trying to accomplish and then ask for modifications. I also ask for a lot of logging with the debug function and we go back and forth about the results. But, it's been pretty trivial to get great functions out of these systems.
    It would be pretty great to have a bunch of markdown files that work as instructions for programming ogscript. I've tried uploading the Custom Panel pdf and I think it's too much to chew on.
    I've also had some success asking the Ross Support bot questions and for code snippets.
    Jesse Alvey
    Tennessee General Assembly
  • 7.  RE: AI Coding and Dashboard
    Posted 2 days ago
    To the point about Claude I actually made a Claude Skill package for Custom Panels: https://github.com/jbeale/ross-dashboard-agent-skills
    There are two things that coding AI agents will struggle with:
    1. Schema discovery, limitations around things (like ES5 in this case)
    2. Not having the ability to validate quickly. Claude Code (like many human developers) heavily depends on the Code->Compile->Debug feedback loop. Giving it at least a schema-driven validation tool helps improve its accuracy dramatically.
    My GitHub library does both. Feel free to steal it, fork it, use it, whatever :)
    Justin Beale
    Broadcast Engineer
    Canyon Hills Community Church
