Very cool.
This is the set of code I was looking for (from OnBeforeOnline):
engine.GetOutputFrameBuffer(FramebufferIndex, output)
' Get the online scene and see if it is the same as this scene
if output.GetSceneOnLayer(Layer, onlinescene) then
if onlinescene.name = self.name then
I can query the values of the scene already online compared to the incoming scene which is doing the querying.
The example provided doesn't do this, but the incoming scene could use the variable "onlinescene" to trigger transitions off while "self" triggers transitions on, right?
Azathoth
Son of Cthulhu
Sent: 08-14-2023 17:46
Subject: Alternate to Transition Logic?
Here's a very very old project showing how we did transition logic using OnBeforeOnline and OnBeforeOffline and comparing the text values of the scenes.
Not sure if this will help you or not, but this is the only example of the old way of transition logic I have.
Sent: 08-09-2023 10:48
Thank you for the info and ideas.
Azathoth
Son of Cthulhu
Sent: 08-09-2023 10:45
you wouldn't really be able to use that unless you're using transition logic, as far as I am aware, thisScene and otherScene are only mean something when scripting in transition logic.
Instead you'd need to use something like getSceneOnLayer and pull the info that way. You'd probably also need to do some trickery with layers.
For example if the active layer was "1" you would pull data from the scene currently on "1" but your oncoming scene would be on "0". Once the other scene is offline and your new scene is full on you can move it from layer "0" to layer "1" ready for the next item.
They're may be other ways to achieve what you want but this is what came into my head, this is all theoretical at this point.
Sent: 08-09-2023 10:40
Unfortunately the SDK documentation isn't always very helpful. How do I know if the takeItem data I am comparing is the current scene or the previous or the next scene?
Better yet, how do you access the previous or next scene?
Azathoth
Son of Cthulhu
Sent: 08-09-2023 10:19
Probably what you'd want to do on the incoming scene onBeforeOnline is collect the data from the currently online scene you intend to playout.
Then onOnline set that scene offline.
