Thank you Richard! Unfortunately I may need to stick with AMP, as I need to get transport position, and it seems like that's not possible through the app's VDCP implementation.
Is there any information as to the arguments each function requires, as well as the format of the returned data, if any?
Andy Bentley
Design Engineer
Skylark Audio Video
Sent: 09-25-2024 06:52
Subject: AMP protocol
Hi Andy,
The ogscript function createAMPSender() will generate a number of functions to send to a device for AMP control, such as Play and Cue, though it's much simpler to use VDCP in Dashboard in my experience.
var amp = ogscript.createAMPSender();ogscript.debug(amp.play);ogscript.debug(amp.cue);
The VDCP commands can be added once creating any button in edit mode of a new custom panel in Dashboard. Once a button is opened in Edit Mode, add a task and VDCP will appear on the left hand side of the menu.
Best regards,
Richard
Richard Crutwell
Ross Video UK
