Thank you James.
That makes it possible to make this into not radio buttons, but regular buttons created from a choice constraint array as well.
Just for anyone that might pick this one up again...
Remember to wrap your code in an if-statement check ing if the value is NOT EQUAL to -1... Just so you dont end up making the code loop forever when you det the value back to -1... Yeah, I tried.
Aleksander Stalsberg
Norway
Sent: 06-20-2022 15:54
Subject: An array of buttons
If you are creating radio toggle buttons for a single parameter, you can 'unselect all' by setting the parameter value to a value that is not on any of the buttons. For example, if you have 0=Wipe, 1=Dissolve, 2=DVE, you can change to no selection by setting the parameter's value to something like '-1'.
James Peltzer
