but then straight after you get the copy from the buffer and also called it "scene" so you're replacing it anyway.
Sent: 08-31-2023 12:45
Subject: Animate 3D Object Live In Framebuffer
Ah ok, because we're already calling up the SceneDirector attached to that scene.
[Nick] [Kubinski]
[Studio Production Specialist]
[Sysmex America Inc.]
[Vernon Hills] [USA]
Sent: 08-30-2023 14:44
you can lose this line.
engine.GetSceneByName("XN-550", scene)
Sent: 08-30-2023 14:26
That works perfectly Simon. Thank you very much for all the help!
dim scene as xpScenedim sd as xpSceneDirectordim channel as xpOutputFrameBufferengine.GetOutputFrameBuffer(0, channel)engine.GetSceneByName("XN-550", scene)channel.GetSceneOnLayer(0, scene)scene.GetSceneDirectorByName("550 Spin", sd)sd.PlayRange(0,200)
[Nick] [Kubinski]
Sent: 08-30-2023 11:46
yeah what your current script is doing is taking the original template online each time.
What you can do instead is this, which would get a scene on layer 0 from your first framebuffer (0). This assume there is a scene online FB 1, layer 0.
Engine.GetOutputFrameBuffer(0, channel)
Sent: 08-30-2023 11:41
That would definitely be of interest. I tried removing "scene.SetOnline(0)" from any subsequent scripts, but then I don't see the animation play out in the Framebuffer.
[Nick] [Kubinski]
Sent: 08-30-2023 04:20
looks good, if the scene is already online you wouldn't need to set it online, you can pull it from the frame buffer instead. Let me know if that would be of interest.
Sent: 08-29-2023 15:56
Thanks Simon! Ok, so just using Playrange to trigger the various sections of the animation, here's what I've got.
dim scene as xpScenedim sd as xpSceneDirectorengine.GetSceneByName("Scene1", scene)scene.GetSceneDirectorByName("Cube Spin", sd)sd.PlayRange(0,50)scene.SetOnline(0)
Also, I didn't know that PlayRange works in reverse too if you switch up the 2 values. I was able to delete the redundant "sd.Playdirection = 0" bit of code.
[Nick] [Kubinski]
Sent: 08-29-2023 05:02
personally I wouldn't use pause and resumes and things with scripting.
I would create triggers for each part of the animation and just use playrange and trigger as required.
Sent: 08-28-2023 15:45
Thanks for the help Simon!
I was able to get some additional control over the animation via the PlayDirection and Track.Enabled properties. I'm a little stuck with the PlayState and Continue properties though. I'm trying to use the same keyboard shortcut/GPI to continue the animation after it has hit the Pause event in the Scene Director. I know there's a Resume Channel function, but I won't be able to pair that with the reverse play direction.
dim scene as xpScenedim sd as xpSceneDirectordim track as xpSceneDirectorTrackdim playState as PlayStateengine.GetSceneByName("Scene1", scene)scene.GetSceneDirectorByName("Front to Front", sd)sd.GetTrackByName("90 Rotation", track)scene.SetOnline(0)sd.PlayDirection = 0track.Enabled = 1sd.PlayState()sd.Continue
[Nick] [Kubinski]
Sent: 08-23-2023 17:14
I would have a single scene director with the entire animation and then from scripts trigger the parts of the scene director you wish to trigger.
For example.
Dim sd as xpSceneDirector
Scene.GetSceneDirectorByName("Spin", sd)
sd.playrange(30, 90)
which would play frames between 30 and 90.
let me know if you need logic beyond that and I can help.
