Hi Dave,
I've attached an example panel snippet below making use of ogScript to send a GET request and receive the response.
To read the response, a callback function needs to be added as an argument to the HTTP ASync Message block:
The callback function is defined here:
From the callback, the response text is parsed into JSON. From the JSON object, you can then read the desired value.
Example Panel:
<?xml version="1.0" encoding="UTF-8"?><abs contexttype="opengear" gridsize="20" id="_top" keepalive="false">
<meta>
<params>
<param access="1" maxlength="0" name="ResponseText" oid="responseText" stateless="true" type="STRING" value="" widget="multiline-text"/>
</params>
</meta>
<button buttontype="push" height="140" left="20" name="Send HTTP GET Request" top="40" width="180">
<task tasktype="ogscript">function myCallback(responseText) {
/*-arg responseText: { "type": "STRING", "widget": "text", "value": ""} -*/
var parsedResponse = "";
var requestedValue = "";
/*! block id=1010,1007,1013,1014,1016,1015,1016 !*/
if ( responseText != null) { parsedResponse = JSON.parse(responseText);
requestedValue = parsedResponse.origin; ogscript.debug( requestedValue); params.setValue('responseText', 0, requestedValue) } else { }
<block id="1010" type="if" x="283" y="10" w="268" INPUT1="ID:1007" OPERATION="does not equal" INPUT2="null" TRUE="ID:1013" FALSE="" IGNORE="" />
<block id="1007" type="responseText_String_variable" x="10" y="10" w="243" color="#404040" SET="" />
<block id="1013" type="customcode" x="854" y="60" w="343" CODE="parsedResponse = JSON.parse(responseText);&amp;#10;requestedValue = parsedResponse.origin;" next="ID:1014" />
<block id="1014" type="ogscript_debug" x="854" y="204" w="243" MESSAGE="ID:1016" next="ID:1015" />
<block id="1016" type="requestedValue_String_variable" x="581" y="204" w="243" color="#ee862a" SET="" />
<block id="1015" type="param_setvalue" x="854" y="276" w="318" PARAM="[root, Params for Community%20Help.grid, Not In Menu, ResponseText (responseText)]" PARAM_DATA="_top&amp;responseText[0]" VALUE="ID:1016" />
/*! block id=1006 !*/
ogscript.asyncHTTP("https://httpbin.org/get", "GET", "application/json", null, myCallback);
<block id="1006" type="ogscript_async" x="176" y="108" w="318" URL="https://httpbin.org/get" METHOD="GET" TYPE="application/json" DATA="null" CALLBACK="myCallback" />
/*!!<checksum>07399059f99438e00e39975a24cdb66a</checksum>!!*/</task>
</button>
<param editable="false" expand="true" height="240" left="20" oid="responseText" showlabel="false" top="260" width="320"/>
<label height="40" left="20" name="Response:" style="txt-align:west;" top="220" width="180"/>
Hopefully this helps, please let me know if you have any further questions!
Michael Quach
