Sent: 11-14-2024 04:24
Subject: Aspect Ration Live Source.
Hey Wajahat I think understand what you are saying, the crop function on a quad doesn't apply the same way to a live sorce as an image but using 2 shaders on 1 mat does.
Sent: 11-14-2024 02:52
I think you misunderstood the point. That's not the case. When we try to crop a live source, it won't work the same as a texture. i habe already got the solution and aired the gfx with the above-described method.
I hope this will help you understand what I'm saying. duplication in not an issue. issue is a crop of live sources. and it solved my dual shader method.
[Wajahat] [Ali]
[Team Lead] [RTG Designer]
[Hum News][Karachi/Islamabad] [Pakistan]
Sent: 11-13-2024 16:09
Have you tried using the "Texture Coordinates" settings in the Live Source Shader instead of the Quad?
If you wanted to have different crops of the same input you can create multiple materials that each use the same live input but have different crops on the Texture coordinates of the shader.
