  • 1.  Assign Datalinq material with script
    Posted 02-12-2024 09:09
    I need to assign datalinq to published objects. It works fine so far for text objects with the following script:
    dim takeItem as xpTakeItem
    dim template as xpPublishedObject
    dim dl as xpDatalinq
    engine.Sequencer.GetFocusedTakeItem(takeItem)
    takeItem.GetPublishedObjectByName("PUBLISHED OBJECT NAME", template)
     template.GetDatalinq(0,dl)
      dl.LinkName = "NAME OF DATASOURCE"
      dl.Column = "COLUMN NAME"
      dl.Row = 88
      dl.Table = "TABLE NAME" & "$"
      template.SetPropertySourceType(0, 1)
    But this does not work when assigned to a quad for changing the material.
    I works when I enter the Datalinq manually but the script does not assign to the object.
    Any ideas what I am doing wrong?
    Bernhard Aschenwald
  • 2.  RE: Assign Datalinq material with script
    Posted 02-14-2024 17:20
    The easiest way to do this would be using "dynamic materials". There are a few things you would have to do first, but basically you would link a hidden text field to the material you wanted, and use that to set the material. Let me know if you want to go down that road.
    Malcolm Thorpe
    xpression design
  • 3.  RE: Assign Datalinq material with script
    Posted 02-21-2024 03:46
    Thanks for your reply.
    This is how I solved it finally (if someone is stumbling over this thread, with the same problem)
    I changed all my quads to datalinq manually since it does not seem to work by scripting like for textobjects.
    (Feature-request: change Data Source on multiple selected objects)
    Then I assigned all datalinq keys with a script in the scene director. So I didn't have to assign 100+ objects manually and can easily make changes if the incoming data structure changes. The scene director with the script is run manually in Layout mode once. So I can even make all the values static in Sequence if needed.
    Best regards
    BernhardAschenwald
    Austria
  • 4.  RE: Assign Datalinq material with script
    Posted 02-21-2024 08:32
    I place a loop script on a scene director to avoid having to assign it manually every time.
    Not exactly what you asked for but this is how I do it.
    'Set Datalinqs
    for i as integer = 1 to 9
    Dim stat as xpTextObject
    scene.GetObjectByName("DATA RAW Jersey " & i, stat)
    stat.Datalinq.LinkName="Dak_XML_Scoreboard"
            stat.Datalinq.Column="Table\Row"
    stat.Datalinq.Row="@Team.Dak_XML@_LINEUP_0" & i &"_NUMBER"
       stat.Datalinq.RefreshLinqsOnChange = false
    Next
  • 5.  RE: Assign Datalinq material with script
    Posted 02-23-2024 02:09
    I have done this as well. But I have not found a way to assign datalinq to quad objects. I can change the datalinq keys with a script but I can't assign it for a static quad.
    Bernhard Aschenwald
    Servus TV
    Red Bull Media House
    Austria
