Even with it you can't directly take an input to an output ... they have to go through the audio mixer and a mix.
Standard "passthrough" is what we can do where the video that is on the Bkgd Bus of the ME/MiniME is what will be used for the VANC/HANC that is sent with those outputs.
Sent: 10-09-2025 11:06
Subject: Audio embed for Carbonite Ultra 24
Thanks for the response Les. So, without the Rave license I can't take embedded audio from an input and send it to the program feed?
Aaron Miller
Tech Director
Mission HIlls Church
Sent: 10-09-2025 10:37
That is not really supported. If you have the Audio Mixer license then you can use a Fader - apply that as a source and use that as the "Mix" that you assign to the outputs as the mix in use.
if you are using an embedder to get the audio from the DM1000 then you should probably be putting that After the Switcher PGM to insert the audio with the PGM feed.
