Hi Duan,
This is the Production Switchers section of the community. I am not real familiar with this card but I am sure that Techsupport will be able to assist and guide you.
I would open a ticket and share this info with them -- also probably supply them the Pinout and connections you have made on both ends (ie the Audio mixer output / connector type and pinout plus the MUX connection port and which pins from the mixer are on which pins of the connector.).
