A salvo does not need to contain ALL of the switches.. This salvo would be triggered by the the Custom Control to set the Output Routing to the correct Audio going out for the Media Store that you want .. ie Salvo called MS1 would ONLY change the ONE destination to Media 1 and then the second Salvo called MS2 will only change that same output (and only that output) to Media Store 2.
Additionally the other question is how big is each Wipe? There is a RAM Cache that allows you to have Multiple Wipes loaded in Cache and then you can just change the Media as part of that Custom Control and use just MS 1 to run them both.. It does not need to reload into Cache every time unless you load things that need space and then it will eject it. In the media Store page there is a Cache Manager that will tell you how much is in each cache and how much space you have left.
Sent: 11-24-2023 12:20
Subject: Audio on aux acuity
It is Ultrix Acuity
I want to this when we are live, I don't want to load different salvos, we only use one salvo for 2 switchers. The main ideie is I want a wipe in ms1 for headlines and a second wipe in ms2 and the director to be able to swich between them or using a CC
Razvan Savu
Video Engineering
DIGI24
Sent: 11-24-2023 09:33
You say Acuity .. but do you mean Ultrix Acuity or the Older Acuity?
Ultrix Acuity the Audio is sent into the Router Audio Matrix and you need to use the Router sub section to switch it.
Easier would be to setup two Salvos on the Router that just switch that Audio Output and then use the RossTalk Events to trigger the two salvos.
